ELLA 03168 4.33 FT. X 28 IN. PETITE ACRYLIC WALK-IN SOAKING BATHTUB IN WHITE WITH RIGHT DRAIN AND DOOR
The Ella Petite Soaking acrylic walk in bathtub. Modeled after the Elite and Royal this space-saver provides a comfortable option for those with even the smallest of bathrooms. The contoured design allows for the same seat width as our original Deluxe which is a full two inches wider. The Ella Petite comes standard with a textured slip resistant floor two safety grab bars and Dual Drain Technology that allows the tub to be drained in as little as 80 seconds for a worry free exit. Ella acrylic baths are built to last with a high gloss cast acrylic shell that is easy to clean scratch resistant and impermeable to mold and bacteria. The shell is then reinforced with a rugged stainless steel frame which distributes weight over 9 leveling legs. The toe kick access panel is designed for a convenient above floor rough-in and can even be removed entirely for a lowered threshold option. By utilizing the wall extension kit and the end access panel(s) your Ella Walk In Bath can easily be installed into a 2 or 3 wall setting and even has the capability to be a free-standing unit so it retro-fits into almost any existing bathroom.
Features
Price: 4266.60
